[Proj] PROJ 5.0.0RC5
Thomas Knudsen knudsen.thomas at gmail.com
Sat Feb 24 10:00:41 PST 2018
Marco,
Thanks for testing! The error message you quote is the first test of
proj_grid_info(), so it very likely is due to missing grids.
/Thomas
2018-02-24 18:43 GMT+01:00 Marco Atzeri <marco.atzeri at gmail.com>:
> On 24/02/2018 18:09, Sebastiaan Couwenberg wrote:
> > On 02/24/2018 05:59 PM, Marco Atzeri wrote:
> >> on cygwin 64 bit it passes most of the tests, except
> >> Reading file
> >> '/cygdrive/e/cyg_pub/devel/proj/prova/proj-5.0.0-0.5a.
> x86_64/src/proj-5.0.0/test/gie/4D-API_cs2cs-style.gie'
> >> proj=latlong nadgrids=nzgd2kgrid0005.gsb ellps=GRS80
> >> Invalid operation definition in line no. 55:
> >>          (null) (errno=PJD_ERR_UNKNOWN/0)
> > This is a known issue, see:
> >   https://github.com/OSGeo/proj.4/issues/819
> > The fix has been merged:
> >   https://github.com/OSGeo/proj.4/pull/820
> > Kind Regards,
> > Bas
> Thanks Bas,
> with that fix I see only one failure
> Reading file
> x86_64/src/proj-5.0.0/test/gie/more_builtins.gie'
> pj_cart_selftest fails with 64
> total: 44 tests succeeded,  4 tests skipped,  1 tests FAILED!
> Not sure if this is due to test without datumgrid
> Regards
> Marco
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180224/d2ba7a80/attachment.html>
