[Proj] PROJ PSC
Thomas Knudsen
knudsen.thomas at gmail.com
Fri Jun 1 01:49:36 PDT 2018
+1 on Howard's suggestion for a PROJ PSC
and
+1 for Frank's third scenario ("We might want to consider the MetaCRS
"experiment" to have run it's course and not worked out particularly well
and dissolve MetaCRS other than perhaps as a potentially mailing list for
coordination of related projects, and proceed with PROJ.4 as an independent
project with it's own PSC, etc.").
Especially, I think we should keep the MetaCRS mailing list (or something
equivalent), since I believe it to be the right place to discuss, develop
and (to some degree) distribute test and validations material for
transformations. I do not think we have seen much development in the IOGP
GIGS test material the last few years, so it is probably not terribly well
curated for the moment. Compiling an alternative, with wider coverage and
in a more accessible format, will be of interest to any provider of
transformation software, not just PROJ.
/Thomas
2018-06-01 10:22 GMT+02:00 Kristian Evers <kreve at sdfe.dk>:
> > The PSC names I listed were chosen because they have
> > been active recently (well, except Frank, who provides institutional
> > memory).
> Based on the activity criteria, I think it is only fair to include Kurt
> Schwehr
> In the PSC as well. Over the last 6 to 12 months Kurt has done a
> tremendous job on improving the robustness of the PROJ code base
> as well taking on the dirty job of improving the overall state of the
> code.
> So if Kurt is interested, I would like to nominate him as a
> member of the bootstrapped PSC.
> /Kristian
> > -----Oprindelig meddelelse-----
> > Fra: proj-bounces at lists.maptools.org [mailto:proj-
> > bounces at lists.maptools.org] På vegne af Howard Butler
> > Sendt: 1. juni 2018 00:01
> > Til: Frank Warmerdam <warmerdam at pobox.com>; PROJ.4 and general
> > Projections Discussions <proj at lists.maptools.org>
> > Emne: Re: [Proj] PROJ PSC
> > Greg,
> > PROJ has never operated under the aegis of anything really. The MetaCRS
> > attempt tried to rally SRS-related software projects under an umbrella
> > within OSGeo, but as I've mentioned on the MetaCRS list [1], it is a
> > failure as an organizing principle for the software projects. We are
> > ostensibly required to vote within MetaCRS to agree on a release, but it
> > is unfortunate make-work that doesn't really protect the release, and it
> > is a motion put forward to an uninterested voting base. I think it is
> > time to dissolve MetaCRS as an authority at least as it pertains to
> > releases and software project management. It's still a great mailing
> > list with access to real expertise on coordinate systems (that overlaps
> > with this mailing list, but not entirely).
> > PROJ needs some kind of body for release organization and technical
> > dispute resolution (we've never had one). A PSC will be a better
> > governance situation than exists now for PROJ. The PSC approach,
> > pioneered by Frank in the MapServer and GDAL communities, would work
> > very well for PROJ. The PSC names I listed were chosen because they have
> > memory).
> > After Frank moved on, I stepped forward as the PROJ maintainer, but I
> > know very little about coordinate systems. I just tried to keep the
> > lights on and sweep the (documentation) floor. Thankfully, Kristian,
> > Charles, Kurt, and Thomas have stepped forward to takeover and provide
> > technical and academic heft to really improve things. Their PROJ efforts
> > are the basis of the GDAL SRS Barn Raising effort https://gdalbarn.com,
> > and without their contributions, there wouldn't be any traffic about
> > code styles, testing frameworks, or object hierarchies. PROJ has seen
> > more activity in the past year than it had in the previous fifteen. Its
> > renewal has been fantastic to watch.
> > Howard
> > [1] https://lists.osgeo.org/pipermail/metacrs/2017-August/000956.html
> > On 5/31/18 4:26 PM, Frank Warmerdam wrote:
> > > Howard,
> > > I can imagine a few ways forward:
> > > - We could just add the named contributors to the MetaCRS PSC and it
> > might
> > > be that only those interested in PROJ.4 vote on PROJ.4 proposals.
> > > - We could form a PROJ PSC and have the MetaCRS PSC authorize it to
> > make
> > > decisions about PROJ.4 on a slightly less officious basis than normal
> PSC
> > > rules.
> > > - We might want to consider the MetaCRS "experiment" to have run it's
> > > course and not worked out particularly well and dissolve MetaCRS other
> > than
> > > perhaps as a potentially mailing list for coordination of related
> projects,
> > > and proceed with PROJ.4 as an independent project with it's own PSC,
> etc.
> > > I'd be happy enough with the third approach. MetaCRS was mostly my
> > > brainchild and I'm willing to agree it is not really a functioning
> thing.
> > > Best regards,
> > > Frank
> > > On Thu, May 31, 2018 at 2:06 PM, Greg Troxel <gdt at lexort.com> wrote:
> > >> Howard Butler <howard at hobu.co> writes:
> > >>> In the interest of self determination, I propose that PROJ form a PSC
> > >>> with the following membership:
> > >> No objection to the concept, but this raises the issue of whether the
> > >> project is operating under the aegis of charitable nonprofit
> > >> corporation. I admit to having no clue about that before, and I'm not
> > >> saying it's a big deal, but clarity is good.
> > >> _______________________________________________
> > >> Proj mailing list
> > >> Proj at lists.maptools.org
> > >> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180601/859baa6f/attachment.html>
More information about the Proj
