[Proj] [gdal-dev] Coordinate system improvements - GDAL, libgeotiff, PROJ barn raising
Mateusz Loskot mateusz at loskot.net
Fri May 18 01:32:13 PDT 2018
On 18 May 2018 at 10:25, Martin Desruisseaux
<martin.desruisseaux at geomatys.com> wrote:
> Le 16/05/2018 à 22:20, Even Rouault a écrit :
> Thanks for the pointers. Some interesting reading to digest. Yes, if the API
> can itself rely on a standard, that could be a good thing.
> In a C/C++ world, it could be:
> State that standard API in C is not a goal (unless someone volunteers for
> defining a large set of pointer to functions).
> Define standard C++ API as a set of classes with virtual or pure virtual
> functions.
> Define subclasses of above C++ classes with PROJ implementation (or
> delegating to PROJ methods in C).
I'd just say, the proposed geo C++ API defined according to OOP design.
That should cover the goal(s) pretty clear.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
