[Proj] [gdal-dev] Coordinate system improvements - GDAL, libgeotiff, PROJ barn raising
Martin Desruisseaux martin.desruisseaux at geomatys.com
Fri May 18 02:48:55 PDT 2018
Le 18/05/2018 à 10:32, Mateusz Loskot a écrit :
> I'd just say, the proposed geo C++ API defined according to OOP
> design. That should cover the goal(s) pretty clear.
Indeed, with the nuance that in a normal OOP project there is no need to
create abstract versions of all major classes.
    Martin
