[Proj] Use of SQLite
Mateusz Loskot mateusz at loskot.net
Mon May 21 07:32:17 PDT 2018
On 21 May 2018 at 16:22, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> On 05/21/2018 12:52 PM, Even Rouault wrote:
>> So the idea would be to import the tables from a EPSG database dump (potentially not
>> in their raw form, but in a modified form to comply with current EPSG Term of Services.
>> We are working with IOGP on that issue) and add auxiliary tables/columns to define:
> The EPSG Terms of Services are still non-free, they don't allow
> modification of the data.
Could you point exactly which terms of http://www.epsg.org/termsofuse
forbid modification of EPSG data?
IANAL, but AFAIU the data can be extracted and modified, just modifications
other than explicitly permitted shall not be attributed to EPSG.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
