[Proj] Use of SQLite
Sebastiaan Couwenberg
sebastic at xs4all.nl
Mon May 21 07:41:34 PDT 2018
On 05/21/2018 04:32 PM, Mateusz Loskot wrote:
> On 21 May 2018 at 16:22, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
>> On 05/21/2018 12:52 PM, Even Rouault wrote:
>>> So the idea would be to import the tables from a EPSG database dump (potentially not
>>> in their raw form, but in a modified form to comply with current EPSG Term of Services.
>>> We are working with IOGP on that issue) and add auxiliary tables/columns to define:
>> The EPSG Terms of Services are still non-free, they don't allow
>> modification of the data.
> Could you point exactly which terms of http://www.epsg.org/termsofuse
> forbid modification of EPSG data?
You should read my message again, I quoted the relevant parts:
>> Point 6.: "The data may be used, copied and distributed subject to
>> the following conditions:", does not include modification.
Grumpy Regards,
Bas
More information about the Proj
