[Proj] Use of SQLite
Mateusz Loskot
mateusz at loskot.net
Mon May 21 07:56:39 PDT 2018
On 21 May 2018 at 16:41, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> On 05/21/2018 04:32 PM, Mateusz Loskot wrote:
>> On 21 May 2018 at 16:22, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
>>> On 05/21/2018 12:52 PM, Even Rouault wrote:
>>>> So the idea would be to import the tables from a EPSG database dump (potentially not
>>>> in their raw form, but in a modified form to comply with current EPSG Term of Services.
>>>> We are working with IOGP on that issue) and add auxiliary tables/columns to define:
>>> The EPSG Terms of Services are still non-free, they don't allow
>>> modification of the data.
>> Could you point exactly which terms of http://www.epsg.org/termsofuse
>> forbid modification of EPSG data?
> You should read my message again, > I quoted the relevant parts:
>>> Point 6.: "The data may be used, copied and distributed subject to
>>> the following conditions:", does not include modification.
I believe I have read it carefully enough.
My point was, that your conclusion above, ie. "does not include modification"
seems to be a bit premature and inaccurate for the overal picture of
what is permitted or and what is not.
Especially, that the ToU only explicitly forbids distribution for profit.
That is why I have asked if there are any additional resources to look at,
where it clearly states modifications are forbidden.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
More information about the Proj
