[Proj] PROJ 5.1.0RC1
Sebastiaan Couwenberg
sebastic at xs4all.nl
Thu May 24 12:25:10 PDT 2018
On 05/24/2018 09:14 PM, Greg Troxel wrote:
> I had the following problems:
> * withdrawn header
> The following file was no longer installed, but this is not noted in
> NEWS:
> -include/org_proj4_Projections.h
This was part of the old JNI wrapper, and no longer required.
> * test failure
> gmake[3]: Entering directory '/home/n0/gdt/pkgsrc-current/pkgsrc/geography/proj/work/proj-5.1.0/test/gie'
> PROJ_LIB=../../nad ../../src/gie 4D-API_cs2cs-style.gie
> Reading file '4D-API_cs2cs-style.gie'
> proj=latlong ellps=WGS84 geoidgrids=tests/test_nodata.gtx
> Invalid operation definition in line no. 287:
> failed to load datum shift file (errno=failed_to_load_grid/-38)
This is: https://github.com/OSGeo/proj.4/issues/1019
And fixed with the attached ignore-failed_to_load_grid.patch
Kind Regards,
Bas
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180524/580ed2c8/attachment.bin>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180524/580ed2c8/attachment.sig>
More information about the Proj
