[Proj] PROJ 5.1.0RC1
Martin Desruisseaux martin.desruisseaux at geomatys.com
Thu May 24 12:58:39 PDT 2018
Le 24/05/2018 à 21:25, Sebastiaan Couwenberg a écrit :
> On 05/24/2018 09:14 PM, Greg Troxel wrote:
>> The following file was no longer installed, but this is not noted in NEWS:
>> -include/org_proj4_Projections.h
> This was part of the old JNI wrapper, and no longer required.
Actually the code implementing org_proj4_Projections.h has been removed
4 years ago, in Proj 4.9.0. That code had memory leaks, which were fixed
by new bindings (essentially the same than today - only upgraded for
Java 9). I guess that the header stayed there by mistake.
    Martin
