[Proj] PROJ 5.1.0RC1
Greg Troxel gdt at lexort.com
Thu May 24 14:19:04 PDT 2018
Martin Desruisseaux <martin.desruisseaux at geomatys.com> writes:
> Le 24/05/2018 à 21:25, Sebastiaan Couwenberg a écrit :
>> On 05/24/2018 09:14 PM, Greg Troxel wrote:
>>> The following file was no longer installed, but this is not noted in NEWS:
>>> -include/org_proj4_Projections.h
>> This was part of the old JNI wrapper, and no longer required.
> Actually the code implementing org_proj4_Projections.h has been removed
> 4 years ago, in Proj 4.9.0. That code had memory leaks, which were fixed
> by new bindings (essentially the same than today - only upgraded for
> Java 9). I guess that the header stayed there by mistake.
That's all fine, but if a header is no longer removed that needs to be
explained in NEWS.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180524/1bde9932/attachment.sig>
