[Proj] WGS84 to NAD27 Coordinate conversion in Android
Greg Troxel gdt at lexort.com
Tue Nov 13 16:07:27 PST 2018
Robb Main <rmain.mws at gmail.com> writes:
> I need to convert WGS84 (lat, long) coordinates from GPS to NAD27 UTM
> Eastings & Northings coordinates, primarily in Canada, in an Android
> environment. To maximize accuracy of the end result, I believe the NTv2
> grid corrections must be applied (though adding 13.5MB to the final
> solution is not desireable).
> I've looked at Proj.4 codebase, and I'm not at all sure it's the best tool
> for this purpose. The JNI support for proj.4 appears to be for java support
> under linux/windows/macos. GDAL uses proj.4 & appears to build for android
> ( https://trac.osgeo.org/gdal/wiki/BuildingForAndroid ), so it _IS_
> possible (with some pain), though I'm not sure this is current info.
> Regardless, GDAL is overkill for my needs, as all I need is coordinates.
I realize you are heading down the java path, but:
It's quite possible to use the NDK to compile C code for android.  As an
example, the tmux package, available from
  https://f-droid.org/en/packages/com.termux/
This even includes clang so you can build C code on the phone.
It should be not super hard to add proj as a package within the termux
ecosystem, so you can install it with apt-get.
Another example is OSMAnd, which has some native code, I'm pretty sure
for routing.
