[Proj] WGS84 to NAD27 Coordinate conversion in Android
Robb Main rmain.mws at gmail.com
Wed Nov 14 05:03:18 PST 2018
Thanks for the suggestion, Nicholas.
I do have the latest NTv2 gsb file (13.5MB!).
Unfortunately, I require an offline solution - internet &/or cell data
connections will often be unavailable.
For that matter, relying on the continued existence of 'governement funded'
tools might also be a concern.
Canada is not immune to arbitrary swings of the economic axe. Or they might
just move the tool to some other URL.
Either way would bork my app.
On Tue, Nov 13, 2018 at 4:02 PM Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> Comments below..
> Le 13 nov. 2018 à 15:03, Robb Main <rmain.mws at gmail.com> a écrit :
> I need to convert WGS84 (lat, long) coordinates from GPS to NAD27 UTM
> Eastings & Northings coordinates, primarily in Canada, in an Android
> environment. To maximize accuracy of the end result, I believe the NTv2
> grid corrections must be applied (though adding 13.5MB to the final
> solution is not desireable).
> Yes this is correct.  The first step will be to go from WGS84 transit to NAD83(CSRS)
> and then to NAD27 using the grid files.  Make sure you have the last
> version of the grid from
> https://open.canada.ca/en/suggested-datasets/ntv2-grid-shift-files-gsb.
> Perhaps the easiest way is to link the android tool to the nrcan web
> tools?  It depends on the availability of wifi or cell coverage.
> http://webappd.geod.nrcan.gc.ca/geod/tools-outils/trx.php?locale=fr&wbdisable=true
> http://webapp.geod.nrcan.gc.ca/geod/tools-outils/ntv2.php
> Good luck
> I've looked at Proj.4 codebase, and I'm not at all sure it's the best tool
> for this purpose. The JNI support for proj.4 appears to be for java support
> under linux/windows/macos. GDAL uses proj.4 & appears to build for android
> ( https://trac.osgeo.org/gdal/wiki/BuildingForAndroid ), so it _IS_
> possible (with some pain), though I'm not sure this is current info.
> Regardless, GDAL is overkill for my needs, as all I need is coordinates.
> I also found the proj4j library (a java port of the proj4 code -
> http://svn.osgeo.org/metacrs/proj4j/trunk/src/README.html), though it
> looks like it was last updated 5 years ago, and its not clear if grid
> support was ever fully implemented / operational.
> I found CTS ( https://github.com/orbisgis/cts ), which is a straight JAVA
> library, implementing the required tranformations & supporting grids, but
> there is little information / no examples on its use. Since it is pure
> java, I expect it would be easier to implement in an android build
> environment.
> Please comment on the above if you have experience with them, or point me
> in the right direction if you have some other suggestion.
> Thank you.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20181114/24b5ee35/attachment.html>
