[Proj] cs2cs - specifying UTM zone on command line
Even Rouault
even.rouault at spatialys.com
Mon Oct 29 14:23:18 PDT 2018
On lundi 29 octobre 2018 21:51:12 CET Andre Joost wrote:
> Am 29.10.18 um 21:14 schrieb Kristian Evers:
> > Okay, so basically encoding the zone in the easting? Better, but I
> > still think it is weird. At least it produces somewhat sane output.
> > Is that operation used by any CRS in the EPSG database?
> surely:
> EPSG:5649 up to 5653 have it, and 4647, 3873 to 3885.
Pedantically, no, at least the way they are described by the EPSG dataset is
that they are using regular Transverse Mercator, with a false easting value
that would be the one given by the "Transverse Mercator Zoned Grid System" for
that zone, but they are still designed for a fixed zone.
EPSG:32600 and EPSG:32700 are the only ones to strictly use TMZGS.
Even
http://www.spatialys.com
More information about the Proj
