[Proj] cs2cs - specifying UTM zone on command line
Even Rouault even.rouault at spatialys.com
Mon Oct 29 14:58:30 PDT 2018
On lundi 29 octobre 2018 21:11:58 CET Kristian Evers wrote:
> Thanks for putting me straight, everyone. I guess there’s a case for such a
> projection afterall!
> How would this best be described in PROJ?
>  +proj=zutm ? +proj=utm +zone=auto, as Robb suggested? Something else?
One possibility for complete generality could be to align on how it is
described by EPSG:
https://www.epsg-registry.org/export.htm?gml=urn:ogc:def:method:EPSG::9824
(or more readable in "1.3.5.2 Transverse Mercator Zoned Grid System" in
guidance 7.2)
And a more understandable example:
https://www.epsg-registry.org/export.htm?wkt=urn:ogc:def:crs:EPSG::32600
So that could be
+proj=tmerc +lon_0=-180 +lat_0=0 +w=6 +k_0=0.9996 +x_0=500000 +y=0
The presence of the parameter w= could be the one that triggers the automated
zone mechanism.
But yes as the only practical use is UTM, "+proj=utm +zone=auto [+south]"
could be used as a shortcut.
http://www.spatialys.com
