[PROJ] Is 16-bit quantization of values / (sub-)millimetric error in grids (sometimes) acceptable ?
Charles Karney
charles at karney.com
Sun Dec 8 08:34:54 PST 2019
I adopted 16-bit integer storage for geoid models with GeographicLib 10
years ago. Back then the main motivation was to minimize the memory
consumption in cases where it was desirable to read the whole model into
memory. This is less of a concern nowadays.
A couple of other observations:
Fixed-point numbers are clearly a preferable format compared with
floating-point numbers for several quantities in the GIS arena. For
latitude, longitudes, azimuths, and heights we usually don't care about
representing huge values (1e100, say) nor with minimizing the *relative*
error for tiny values (1e-100, say). So fixed-point numbers are
sometimes a natural choice. (Representing this data is floats
inevitably confounds compression algorithms because of what is
essentially noise in the least significant bits of the numbers.)
GeographicLib's Geoid class makes an attempt to ameliorate the
quantization errors when using cubic interpolation by doing an
over-determined fit to 12 points in the grid. This reduces the RMS
error somewhat, but presumably does not affect the maximum error.
I confess that I've always had qualms about this representation for
geoid heights. 16-bits is just barely enough for EGM2008.
If the concern is the size of the compressed data on disk, perhaps it is
worth being a little bit more ambitious. How about representing the
data as integers (let's say 32-bit unsigned, but maybe it would be good
to allow for 64-bit and for signed) with an offset and scale? Then the
question is what is the "best" way of compressing this data with the
following criteria:
* do a good job is the range of the data is restricted, i.e., if the
integer might have fit into 16-bits.
* do a good job given that the data is usually a slowly varying function
in 1, 2, or 3 dimensions.
* allow random access without too much overhead.
* an implementation is freely available.
Some of these issues are addressed by the LASzip compression scheme for
LAS data.
On 12/8/19 10:10 AM, Even Rouault wrote:
> Hi,
> I'm experimenting with encoding grids with 16-bit integer values, with an
> offset and scale, instead of using IEEE 32-bit floats. There's some connection
> with my previous thread about accuracies of NTv2...
> Let's for example take the example of egm08_25.gtx. It is 149.3 MB large
> If converting it into a IEEE 32-bit float deflate-compressed (with floating-
> point predictor) tiled geotiff, it becomes 80.5 MB large (the compression
> method and floatin-point predictor are fully lossless. There's bit-to-bit
> equivalence for the elevation values regarding the original gtx file)
> Now observing that the range of values is in [-107,86], I can remap that to
> [0,65535] with an offset of -107 and scale of (86 - -107) / 65535 ~= 0.0029
> The resulting deflate-compressed (with integer predictor) tiled GeoTIFF is now
> 23.1 MB large !
> Looking at the difference between the unscaled quantized values and the
> original ones, the error is in the [-1.5 mm, 1.5 mm] range (which is expected,
> being the half of the scale value), with a mean value of 4.5e-6 metre (so
> centered), and a standard deviation of 0.85 mm
> After that experimentation, I found this interesting page of the GeographicLib
> documentation
> https://geographiclib.sourceforge.io/html/geoid.html
> which compares the errors introduced by the gridding itself and interpolation
> methods (the EGM model is originally a continuous model), with/without
> quantization. And one conclusion is "If, instead, Geoid were to use data files
> without such quantization artifacts, the overall error would be reduced but
> only modestly". Actually with the bilinear interpolation we use, the max and
> RMS errors with and without quantization are the same... So it seems perfectly
> valid to use such quantized products, at least for EGM2008, right ?
> Now looking at horizontal grids, let's consider Australia's
> GDA94_GDA2020_conformal.gsb. It is 83 MB large (half of this size due to the
> error channels, which are set to a dummy value of -1...)
> Converting it to a compressed tiled Float32 tif (without those useless error
> channels), make it down to 4.5 MB.
> And as a quantitized uint16 compressed tif, down to 1.4 MB (yes, almost 60
> times smaller than original .gsb file). The maximum scale factor is 1.5e-7
> arcsecond, hence a maximum error of 2.3 micrometre... I'm pretty sure we're
> several order of magnitudes beyond the accuracy of the original model, right ?
> In EPSG this transformation is reported to have an accuracy of 5cm.
> The fact that we get such a small scale factor is due to GDA94 -> GDA2020
> conformal being mostly a uniform shift of ~1.8 m and that the grids is
> mentioned to "Gives identical results to Helmert transformation GDA94 to
> GDA2020 (1)"
> If we look at the France' ntf_r93.gsb, which has shifts of an amplitude up to
> 130m, the maximum error introduced by the quantization is 0.6 mm. I would tend
> to think this is also acceptable (given the size of that particular file is
> small, compression gains are quite neglectable, but this is mostly to look if
> we can generalize such mechanism). What puzzles me is that in
> https://geodesie.ign.fr/contenu/fichiers/documentation/algorithmes/notice/
> NT111_V1_HARMEL_TransfoNTF-RGF93_FormatGrilleNTV2.pdf where they compare the
> NTv2 approach regarding their native 3D geocentric correction approach, they
> underline in red a sample point where the difference between the 2 models is
> 1.2 mm, as if it had really some importance. For that test point, using the
> quantized approach would increase this difference to 1.3 mm. But when looking
> at the accuracy reported in the grid at that point it is 1.6e-3 arc-second
> (which is the minimum value for the latitude error of the product, by the
> way), ie 5cm, so it seems to me that discussing about millimetric error
> doesn't make sense.
> In EPSG this transformation is reported to have an accuracy of 1 metre (which
> is consistent with the mean value of the latitude shift error)
> Now, let's look at the freshly introduced BWTA2017.gsb file. 392 MB large
> As a Float32 compressed geotiff: 73 MB (5.4x compression rate)
> As a Int16 compressed geotiff: 26 MB (15x compression rate)
> Maximum error added by quantization for latitude shift: 0.25 mm
> Minimum error value advertized for latitude shift: 1.61e-5 arc-second (not
> completely sure about the units...), ie 0.5mm
> Mean error value advertized for latitude shift: 6.33e-5 arc-second, ie 1.9mm
> Interestingly when looking at the ASCII version of the grid, the values of the
> shifts are given with a precision of 1e-6 arcseconds, that is 0.03 mm !
> For Canadian NTv2_0.gsb, on the first subgrid, the quantization error is
> 0.9 mm for the latitude shift. The advertized error for latitude is in [0,
> 13.35 m] (the 0.000 value is really surprising. reached on a couple points
> only), with a mean at 0.27 m and stddev at 0.48 m. In EPSG this transformation
> is reported to have an accuracy of 1.5 metre
> So, TLDR, is it safe (and worth) to generate quantized products to reducte by
> about a factor of 2 to 3 the size of our grids compared to unquantized
> products, when the maximum error added by the quantization is ~ 1mm or less ?
> or will data producers consider we damage the quality of products they
> carefully crafted ? do some users need millimetric / sub-millimetric accuracy
> Or do we need to condition quantization to a criterion or a combination of
> criteria like:
> - a maximum absolute error that quantization introduces (1 mm ? 0.1 mm ?)
> - a maximum value for the ratio between the maximum absolute error that
> quantization introduces over the minimum error value advertized (when known)
> below some value ? For the BWTA2017 product, this ratio is 0.5. For
> ntf_r93.gsb, 0.012. For NTv2_0.gsb, cannot be computed given sothe min error
> value advertized is 0...
> - or, variant of the above, a maximum value for the ratio between the maximum
> absolute that quantization introduces over the mean of the error value
> advertized (when known). For the BWTA2017 product, this ratio is 0.13. For
> ntf_r93.gsb, 5.5e-4. For NTv2_0.gsb, 3.3e-3
> - and perhaps consider that only for products above a given size (still larger
> than 10 MB after lossless compression ?)
> Jochem mentionned in the previous thread that the Netherlands grids have an
> accuracy of 1mm. I'm really intrigued by what that means. Does that mean that
> the position of control points used to build the grid is known at that
> accuracy, both in the source and target systems, and that when using bilinear
> interpolation with the grid, one remains within that accuracy ? Actually both
> the rdtrans2008.gsb and rdtrans2018.gsb grids report an accuracy of 1mm, but
> when comparing the positions corrected by those 2 grids, I get differences
> above 1mm.
> echo "6 53 0" | cct -d 9 +proj=hgridshift +grids=./rdtrans2008.gsb
> 5.999476046 52.998912757
> echo "6 53 0" | cct -d 9 +proj=hgridshift +grids=./rdtrans2018.gsb
> 5.999476020 52.998912753
> echo "52.998912757 5.999476046 52.998912753 5.999476020" | geod -I
> +ellps=GRS80
> -104d18'21.49" 75d41'38.51" 0.002
> That's a difference of 2 mm. I get that difference on a few other "random"
> points.
> If applying the quantization on rdtrans2018.gsb, we'd add an additional
> maximal error of 0.6 mm. The grid being 1.5 MB uncompressed, and 284 KB as a
> losslessly compressed TIFF, quantization isn't really worth considering
> (reduces the file size to 78 KB)
> Even
More information about the PROJ
