[PROJ] PROJ 6.3.0RC1
    Kristian Evers
    kreve at sdfe.dk
    Sat Dec 28 06:30:11 PST 2019
Good catch! I was notified by git that git-lfs was missing from my path.
I fixed that and git pull’ed again to rectify the problem. I should have
done a ‘git lfs pull’ instead. Lesson learned :-)
I’ll update the europe package with a RC2 tonight. Hopefully that is
the only problem in this batch of release candidates.
/Kristian
> On 28 Dec 2019, at 14:56, Even Rouault <even.rouault at spatialys.com> wrote:
>> Europe-1.5RC1:
>> http://download.osgeo.org/proj/proj-datumgrid-europe-1.5RC1.zip
> A RC2 will be needed for that one. BWTA2017.gsb is the git-lfs text file, not
> the actual content.
> I committed the .gitattributes file only on Dec 20 whereas the .gsb file was
> committed on Nov 30, so if you have "git pull" in-between, that might perhaps
> explain you only got the link and not the actual content. (Testing a fresh git
> clone with git-lfs in the PATH correctly retrieves the file.)
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ
