[PROJ] Proj6 Docs
Even Rouault even.rouault at spatialys.com
Sat Feb 16 13:56:09 PST 2019
> Ah, I see! I cannot get it to work though, I am trying this:
> https://gist.github.com/pramsey/22127622023e88cd415cd1524db0a285#file-proj-c
> -L19-L24
> <https://gist.github.com/pramsey/22127622023e88cd415cd1524db0a285#file-proj
> -c-L19-L24>
> And getting:
>  proj_get_source_crs: Object is not a BoundCRS or a CoordinateOperation
>  proj_get_target_crs: Object is not a BoundCRS or a CoordinateOperation
> What’s my mistake?
Ah... That gets tricky becase EPSG:3005 uses NAD83 datum, and there's no single transformation path from WGS84 to NAD83
If you add
printf("definition: %s\n", proj_pj_info(pj).definition);
you'll see in the output:
definition: unavailable until proj_trans is called
And if you do:
$ src/projinfo -s EPSG:4326 -t EPSG:3005 --spatial-test intersects -o PROJ
you'll see:
Operation n°1:
unknown id, Inverse of NAD83 to WGS 84 (1) + British Columbia Albers, 4 m, North America - Canada and USA (CONUS, Alaska mainland)
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +proj=aea +lat_0=45 +lon_0=-126 +lat_1=50 +lat_2=58.5 +x_0=1000000 +y_0=0 +ellps=GRS80
Operation n°2:
unknown id, Inverse of NAD83 to WGS 84 (41) + British Columbia Albers, 1 m, USA - Oregon and Washington
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +inv +proj=hgridshift +grids=WO +step +proj=aea +lat_0=45 +lon_0=-126 +lat_1=50 +lat_2=58.5 +x_0=1000000 +y_0=0 +ellps=GRS80
Operation n°3:
unknown id, Inverse of NAD83 to WGS 84 (20) + British Columbia Albers, 1 m, USA - Idaho and Montana - west of 113°W
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +inv +proj=hgridshift +grids=wmhpgn.gsb +step +proj=aea +lat_0=45 +lon_0=-126 +lat_1=50 +lat_2=58.5 +x_0=1000000 +y_0=0 +ellps=GRS80
Operation n°4:
unknown id, Null geographic offset from WGS 84 to NAD83 + British Columbia Albers, unknown accuracy, World
PROJ string:
Operation n°5:
unknown id, Inverse of NAD83 to WGS 84 (8) + British Columbia Albers, 1 m, Canada - Alberta
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +inv +proj=hgridshift +grids=AB_CSRS.DAC +step +proj=aea +lat_0=45 +lon_0=-126 +lat_1=50 +lat_2=58.5 +x_0=1000000 +y_0=0 +ellps=GRS80
So proj_create_crs_to_crs() see that there are several potential transformation and keep the list internally.
When proj_trans() is invoked it picks up the most appropriate transformation from the above according to the current coordinate value.
So in that case, the PJ object is in a rather particular state and has no proper single CoordinateOperation stored, but a list of candidates that is hidden from the API.
I could potentially fix proj_get_source/target_crs() to properly behave in that situation
since all candidate transformations share the same source and target SRS. Perhaps I should
since the above explanation are probably just an implementation detail for your use case ?
Even
http://www.spatialys.com
More information about the PROJ mailing list
