[PROJ] Proj6 Docs
    Even Rouault
    even.rouault at spatialys.com
    Sat Feb 16 14:13:56 PST 2019
> > Perhaps I should since the above explanation are probably
> > just an implementation detail for your use case ?
OK, fix just pushed.
> Yes, I’m only looking for source/target so I can figure out if I need to do
> an axis swap before (or after) feeding the transformation. Is there a
> decent way to stick a swap directing onto the end/start of the
> transformation so I get it “for free” when I run proj_trans?
That would involve hand editing the pipeline.
proj_as_proj_string(ctx, P, PJ_PROJ_5, nullptr) will return a PROJ string that
generally begin with "+proj=pipeline" (not in your case with alternatives
though)
If just after that and before the first +step, you insert
+step +proj=axisswap +proj=axisswap +order=2,1
(or you append it at the end if you want to reverse the order for the output)
And then you can recreate a PJ pipeline with that string with proj_create()
Or course if you do an axisswap just before/after another one, their effect
cancels each other, so you could optimize by removing it;
Even
http://www.spatialys.com
More information about the PROJ
