[PROJ] PROJ 6.0.0RC3
Kristian Evers
kreve at sdfe.dk
Tue Feb 26 11:37:19 PST 2019
Nice work, Even! I’ll put out RC4 once the CI tests has run. Hopefully this will be the last one :-)
/Kristian
> On 26 Feb 2019, at 19:42, Even Rouault <even.rouault at spatialys.com> wrote:
>> The C++ unit tests also fail on io.wkt_parsing_with_parenthesis. I've been
>> unable to determine the cause. Presumably the use of non-ASCII characters in
>> hexadecimal form. Not sure why this would be netBSD specific... But this is
>> is really a non-critical test.
> Actually was a misuse of isspace() on non-ASCII characters. Could have shown
> up on other platforms as well. Just fixed in the
> https://github.com/OSGeo/proj.4/pull/1293 as well
> Now 'gmake check' passes on netBSD 8
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ
