[PROJ] PROJ 6.0.0RC4
Even Rouault
even.rouault at spatialys.com
Wed Feb 27 00:15:03 PST 2019
> My discrepancy list follows. The first four seem to be files removed
> from the included datumgrids, and I wonder if that's the plan. (And if
> so, if it merits being in NEWS.)
Yes, those removals are intended.
But I don't see the addition of the new proj.db file (but I assume you took it
into account since it is mentionned in NEWS). This is critical to have it
installed in $prefix/share/proj
> The header files look like they are intended to be installed, but given
> that there are in 5.2.0 4 header files installed with 1 deprecated, I
> wanted to check. Is this list of files "Added C++ API exposing
> ISO19111 functionality" from NEWS?
Yes all .h and .hpp files you mention below should be installed
> ERROR: ************************************************************
> ERROR: The following files are in the PLIST but not in
> /home/n0/gdt/pkgsrc-current/pkgsrc/geography/proj/work/.destdir/usr/pkg:
> ERROR:
> /home/n0/gdt/pkgsrc-current/pkgsrc/geography/proj/work/.destdir/usr/pkg/sha
> re/proj/IGNF ERROR:
> re/proj/epsg ERROR:
> re/proj/esri ERROR:
> re/proj/esri.extra ERROR:
> ************************************************************ ERROR: The
> /home/n0/gdt/pkgsrc-current/pkgsrc/geography/proj/work/.destdir/usr/pkg but
> not in the PLIST: ERROR:
> /home/n0/gdt/pkgsrc-current/pkgsrc/geography/proj/work/.destdir/usr/pkg/inc
> lude/proj/common.hpp ERROR:
> lude/proj/coordinateoperation.hpp ERROR:
> lude/proj/coordinatesystem.hpp ERROR:
> lude/proj/crs.hpp ERROR:
> lude/proj/datum.hpp ERROR:
> lude/proj/io.hpp ERROR:
> lude/proj/metadata.hpp ERROR:
> lude/proj/nn.hpp ERROR:
> lude/proj/util.hpp ERROR:
> lude/proj_constants.h ERROR:
> lude/proj_experimental.h ERROR:
> lude/proj_symbol_rename.h _______________________________________________
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ
