[PROJ] PROJ 6.0.0RC4
Kristian Evers
kreve at sdfe.dk
Wed Feb 27 01:56:33 PST 2019
> On 27 Feb 2019, at 10:43, Elliott Sales de Andrade <quantum.analyst at gmail.com> wrote:
> On Tue, 26 Feb 2019 at 16:19, Kristian Evers <kreve at sdfe.dk> wrote:
>> Following the issues reported with NetBSD builds I have just uploaded PROJ 6.0.0RC4.
>> Thanks to Even for cracking this one so quickly!
>> Links are here:
>> https://download.osgeo.org/proj/proj-6.0.0RC4.tar.gz (https://download.osgeo.org/proj/proj-6.0.0RC4.tar.gz.md5)
>> https://download.osgeo.org/proj/proj-6.0.0RC4.zip (https://download.osgeo.org/proj/proj-6.0.0RC4.zip.md5)
> With these versions, all the build failures I saw are fixed, and it
> scratch builds on all Fedora systems:
> https://koji.fedoraproject.org/koji/taskinfo?taskID=33077369
> Locally, if I install all released regional datumgrid tarballs, then
> the build is fine. However, if I install
> proj-datumgrid-north-america-1.2RC2, then I see the following failure
> (it is okay with 1.1, maybe because the required file is not in
> there):
On the CI targets we only run tests with the main grid package installed,
so this is likely because a better transformation is picked up when the
regional grids are available. I wouldn’t worry about this error.
/Kristian
> Running ../../test/cli/testntv2 using ../../src/cs2cs:
> doing tests into file ntv2_out, please wait
> diff ntv2_out with ntv2_out.dist
> 10c10
> < 111d00'00.000"W 46d00'00.000"N 0.0 111d0'3.1897"W 45d59'59.7489"N 0.000
>> 111d00'00.000"W 46d00'00.000"N 0.0 111d0'3.1549"W 45d59'59.7528"N 0.000
>> I would appreciate swift feedback from those who experienced build failures with RC3,
>> so that we have amble time for a PSC vote before the scheduled release on Friday.
>> /Kristian
> Elliott
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ
