[PROJ] PROJ 6.0.0RC4
Even Rouault even.rouault at spatialys.com
Wed Feb 27 02:00:49 PST 2019
On mercredi 27 février 2019 04:43:35 CET Elliott Sales de Andrade wrote:
> On Tue, 26 Feb 2019 at 16:19, Kristian Evers <kreve at sdfe.dk> wrote:
> > Following the issues reported with NetBSD builds I have just uploaded PROJ
> > 6.0.0RC4. Thanks to Even for cracking this one so quickly!
> > Links are here:
> > https://download.osgeo.org/proj/proj-6.0.0RC4.tar.gz
> > (https://download.osgeo.org/proj/proj-6.0.0RC4.tar.gz.md5)
> > https://download.osgeo.org/proj/proj-6.0.0RC4.zip
> > (https://download.osgeo.org/proj/proj-6.0.0RC4.zip.md5)
> With these versions, all the build failures I saw are fixed, and it
> scratch builds on all Fedora systems:
> https://koji.fedoraproject.org/koji/taskinfo?taskID=33077369
> Locally, if I install all released regional datumgrid tarballs, then
> the build is fine. However, if I install
> proj-datumgrid-north-america-1.2RC2, then I see the following failure
> (it is okay with 1.1, maybe because the required file is not in
> there):
Yes, that's "expected". testntv2 requires base proj-datumgrid (all CI setups
install proj-datumgrid only), but is going to react differently if other extra
grids are installed.
http://www.spatialys.com
More information about the PROJ mailing list
