[PROJ] Static/Dynamic Webmapping Problem version 2.0
Strong, Scott (DPIPWE) Scott.Strong at dpipwe.tas.gov.au
Wed Jul 17 22:54:16 PDT 2019
On mercredi 17 juillet 2019 17:47:34 Even Rouault <even.rouault at spatialys.com>
wrote:
>That doesn't make sense to me. There will be a ~1.8 m shift between the
>coordinates of the same monument expressed in GDA94 and GDA2020 due to plate
>motion between 1994 and 2020. That's the whole point of having GDA2020
>"resynchronized" with ITRF at 2020.00, or I'm missing something...
Correct - you are not missing something.
See https://www.icsm.gov.au/gda2020 but in particular the 3 minute video embedded in the page - https://vimeo.com/191566518
Scott
CONFIDENTIALITY NOTICE AND DISCLAIMER
The information in this transmission may be confidential and/or protected by legal professional privilege, and is intended only for the person or persons to whom it is addressed. If you are not such a person, you are warned that any disclosure, copying or dissemination of the information is unauthorised. If you have received the transmission in error, please immediately contact this office by telephone, fax or email, to inform us of the error and to enable arrangements to be made for the destruction of the transmission, or its return at our cost. No liability is accepted for any unauthorised use of the information contained in this transmission.
More information about the PROJ mailing list
