[PROJ] [EXTERNAL] [gdal-dev] Static/Dynamic datum problems
Even Rouault
even.rouault at spatialys.com
Tue Jun 25 05:40:50 PDT 2019
> The timestamp of a
> coordinate has to be the observation time of the coordinate and the
> timestamp must not be changed during transformations (otherwise you can’t
> do the reverse transformation).
Unless you do a point motion operation, right ?
Quoting http://docs.opengeospatial.org/as/18-005r4/18-005r4.html#68 :
"""The coordinates of a data set may be changed to any other epoch. Plate
motion or other crustal deformation models are often used for this when
estimated coordinate velocities are not available. Such models facilitate for
example the change of coordinates from being referenced to ITRF2008 at epoch
2017.53 to being referenced to ITRF2008 at epoch 2005.0."""
Which would be the case if you want to create for example a global raster
dataset : you want all tiles to be referenced to the same coordinate epoch.
But this would be the final step in the coordinate transformation process.
In a vector dataset, you may accept different features to be at different
coordinate epochs.
To be noted tha the EPSG dataset is currently rather sparse in the area of
point motion operations. There's just a single one available for the Canadian
NAD83(CSRS)v6 case using a velocity grid. So currently if you have a
coordinate referenced to a ITRF CRS, you can't transform it easily to another
epoch in this CRS. Or in the Australian case, you'd have to go back to GDA2020
using the ITRF2014<-->GDA2020 time dependent Helmet transformation... :
From ITRF2014 at 2018.00 to GDA2020
$ echo "-30 120 0 2018.00" | cs2cs -f "%.9f" EPSG:9000 EPSG:7844
-29.999998944 120.000000758 -0.000339830 2018.00
From GDA2020 to ITRF2014 at 2025.00
$ echo "-29.999998944 120.000000758 -0.000339830 2025.00" | \
cs2cs -I -f "%.9f" EPSG:9000 EPSG:7844
-29.999996305 120.000002652 -0.001189402 2025.00
Which makes it obvious that, even when/if we have point motion operation
available to do directry CRS A @ epoch 1 -> CRS A @ epoch B, we don't have a
clean way currently in PROJ of specifying the target coordinate epoch.
Actually I could do it in just one step by hacking the ITRF2014->GDA2020
pipeline and using t_epoch=2025.00 to make it a ITRF2014 @ input_epoch ->
ITRF2014 @ 2025.00 valid for Australia (probably only within a few years
around epoch 2020.00, which also brings into light the lack in the EPSG
dataset of metadata indicating the time range against which a coordinate
operation is valid with the published accuracy...):
$ echo "-30 120 0 2018.00" | cct -d 9 +proj=pipeline \
+step +proj=axisswap +order=2,1 \
+step +proj=unitconvert +xy_in=deg +xy_out=rad \
+step +proj=cart +ellps=GRS80 \
+step +proj=helmert +x=0 +y=0 +z=0 +rx=0 +ry=0 +rz=0 +s=0 \
+dx=0 +dy=0 +dz=0 +drx=0.00150379 +dry=0.00118346 +drz=0.00120716 +ds=0 \
+t_epoch=2025 +convention=coordinate_frame \
+step +inv +proj=cart +ellps=GRS80 \
+step +proj=unitconvert +xy_in=rad +xy_out=deg \
-29.999996305 120.000002652 -0.001189396 2018.0000
Except that 2018.000 in the output should be read as 2025 given the hack...
> The problem is that it is impossible in practice
> since there is no standard that describes how to do this. The OGC Simple
> Features standard which most file formats are based on simply doesn’t
> include time as a dimension.
You probably want the time to be included as a general metadata of the
geometry rather than a per-vertex value (hopefully a single geometry is
referenced to the same epoch...), which would be along the CoordinateMetadata
class mentionned by Martin.
Yes, there is the issue of standards, but then it must percolate down to file
/ geospatial database formats. GeoPackage and PostGIS for example are
extensions of the WKB encoding of Simple Features, so if the later is updated,
then the former might be able to upgrade. For web services, GML / WFS should
be upgraded as well, both on the response side (you need the coordinate epoch)
and in the request side (you probably also need to be able to specify that you
want geometries at a given coordinate epoch)
The issue is the same with raster formats. How to do encode in a GeoTIFF the
coordinate epoch
(I've just created https://github.com/opengeospatial/geotiff/issues/78), etc
I guess that's why people keep creating new static CRS. That's so much
convenient given the inertia on the file format side (how do you fix
shapefiles to include coordinate epoch... A new sidecar file myshape.epoch :-)
Even
http://www.spatialys.com
More information about the PROJ
