[PROJ] PROJ debug build on Windows ?
Even Rouault even.rouault at spatialys.com
Fri Jun 28 07:17:05 PDT 2019
Anyone knows if there's an issue to build PROJ in debug mode on Windows ?
(please keep Joaquim in CC as I'm not sure he's subscribed here)
Even
----------  Forwarded Message  ----------
Subject: RE: [gdal-dev] kml file with line length too long
Date: vendredi 28 juin 2019, 14:07:01 CEST
From: Joaquim Manuel Freire Luís <jluis at ualg.pt>
To: Even Rouault <even.rouault at spatialys.com>
CC: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
|>Nothing strikes me as obviously wrong (just missing CPLFree() on pszWKT and
|>pszProj4, but that's not the cause of your issue).
|>You'll have to use your favorite debugging tool: gdb, valgrind ...
Hmm, landed in proj_as_wkt() but I'm not being able to build a proj debug. No
matter setting
		-DCMAKE_BUILD_TYPE=Debug ^
		-DCMAKE_CONFIGURATION_TYPES=Debug ^
In cmake, I end up with a release build
http://www.spatialys.com
More information about the PROJ mailing list
