[PROJ] PROJ debug build on Windows ?
jmfluis at gmail.com
Fri Jun 28 07:23:59 PDT 2019
Sorry (Even), false alarm. I have also a ConfigUser.cmake file that has the build type declared there too and apparently it takes precedence to the setting in command line. I have a debug dll now.
... proceeding with the debug.
|>-----Original Message-----
|>From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Even Rouault
|>Sent: Friday, June 28, 2019 3:17 PM
|>To: proj at lists.osgeo.org
|>Cc: Joaquim Manuel Freire Luís <jluis at ualg.pt>
|>Subject: [PROJ] PROJ debug build on Windows ?
|>Hi,
|>Anyone knows if there's an issue to build PROJ in debug mode on Windows ?
|>(please keep Joaquim in CC as I'm not sure he's subscribed here)
|>Even
|>---------- Forwarded Message ----------
|>Subject: RE: [gdal-dev] kml file with line length too long
|>Date: vendredi 28 juin 2019, 14:07:01 CEST
|>From: Joaquim Manuel Freire Luís <jluis at ualg.pt>
|>To: Even Rouault <even.rouault at spatialys.com>
|>CC: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
|>|>Nothing strikes me as obviously wrong (just missing CPLFree() on
|>|>pszWKT and pszProj4, but that's not the cause of your issue).
|>|>You'll have to use your favorite debugging tool: gdb, valgrind ...
|>Hmm, landed in proj_as_wkt() but I'm not being able to build a proj debug. No
|>matter setting
|> -DCMAKE_BUILD_TYPE=Debug ^
|> -DCMAKE_CONFIGURATION_TYPES=Debug ^
|>In cmake, I end up with a release build
|>Spatialys - Geospatial professional services http://www.spatialys.com
|>_______________________________________________
|>PROJ mailing list
|>PROJ at lists.osgeo.org
|>https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ
