[PROJ] Release schedule between version 6.0.0 and 7.0.0
Bas Couwenberg
sebastic at xs4all.nl
Tue Mar 5 07:00:42 PST 2019
On 2019-03-05 15:48, Kristian Evers wrote:
> I've set up a very simple GitHub wiki page for this purpose. I've just
> added
> GDAL as an example for now. Feel free to add more to this.
> https://github.com/OSGeo/proj.4/wiki/proj.h-adoption-status
This is one step further than required for compatibility with PROJ 6
(and 5.x).
The biggest issue is the removal of projects.h, so dependent projects
need to use proj_api.h or proj.h. The former is sufficient to build
successfully with PROJ 6 (and 5.x).
Did you remove the other wiki pages on purpose? The wiki is very empty
now, any links to the old pages will be broken now.
Kind Regards,
Bas
More information about the PROJ
