[PROJ] Release schedule between version 6.0.0 and 7.0.0
Kristian Evers kreve at sdfe.dk
Tue Mar 5 07:32:56 PST 2019
I am also interested in knowing if projects will be able to build against
PROJ 7 in a years' time, hence the three columns.
Feel free to change my template if you think there's a better way to keep
track of things. This was just a very quick and dirty job to get the ball rolling.
Yes, I purposely removed most of the other wiki pages. See my other email
for an explanation why.
/Kristian
-----Oprindelig meddelelse-----
Fra: PROJ <proj-bounces at lists.osgeo.org> På vegne af Bas Couwenberg
Sendt: 5. marts 2019 16:01
Til: proj at lists.osgeo.org
Emne: Re: [PROJ] Release schedule between version 6.0.0 and 7.0.0
On 2019-03-05 15:48, Kristian Evers wrote:
> I've set up a very simple GitHub wiki page for this purpose. I've just
> added
> GDAL as an example for now. Feel free to add more to this.
> https://github.com/OSGeo/proj.4/wiki/proj.h-adoption-status
This is one step further than required for compatibility with PROJ 6
(and 5.x).
The biggest issue is the removal of projects.h, so dependent projects
need to use proj_api.h or proj.h. The former is sufficient to build
successfully with PROJ 6 (and 5.x).
Did you remove the other wiki pages on purpose? The wiki is very empty
now, any links to the old pages will be broken now.
Kind Regards,
Bas
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
