[PROJ] Proj 6 API questions
Kristian Evers kreve at sdfe.dk
Tue Mar 19 03:15:19 PDT 2019
> Sure -- got any tips on where this is done? I'm new to the proj code.
I am no expert in this, but generally a good starting point is here:
https://github.com/OSGeo/proj.4/tree/master/data/sql
I would recommend adding a new SQL file instead of appending an
existing one.  You will probably have to adjust makefiles in the parent
directory as well.
/Kristian
More information about the PROJ mailing list
