[PROJ] Helmert transform
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Wed Mar 20 07:46:01 PDT 2019
Hi Dean,
Do you use existing parameters for the Helmert transformation or do you estimate parameters yourself?
The quality and residuals of estimated parameters depends on the quality and distribution of the coordinates used for the estimation. For a Helmert transformation between a triangulated and a GNSS data set of an entire country of some hundreds of kilometres across, residuals over 1 metre are not uncommon. For two datasets of permanent GNSS stations of a small area, residuals can be under 1 centrimetre.
Kind regards, Jochem
Van: PROJ <proj-bounces at lists.osgeo.org> Namens Dean Howell
Verzonden: woensdag 20 maart 2019 06:01
Aan: proj at lists.osgeo.org
Onderwerp: [PROJ] Helmert transform
Hello all,
We have a project that is using the helmert transformation and we are trying to get an understanding of what level of residuals is acceptable and how we interpret the results.
If anyone has experience in using the helmert transformation, I would be interested in your feedback.
Regards
Dean Howell
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190320/18c60b2d/attachment-0001.html>
More information about the PROJ
