[PROJ] Helmert transform
Even Rouault
even.rouault at spatialys.com
Wed Mar 20 08:03:39 PDT 2019
On mercredi 20 mars 2019 15:31:14 CET Dean Howell wrote:
> Hello all,
> We have a project that is using the helmert transformation and we are
> trying to get an understanding of what level of residuals is acceptable and
> how we interpret the results.
> If anyone has experience in using the helmert transformation, I would be
> interested in your feedback.
Dean,
if you use Helmert transformations from the EPSG dataset, they are accompanied
with their accuracy.
For example, if you use latest PROJ 6,
$ projinfo -s EPSG:4214 -t EPSG:4326 --spatial-test intersects
Candidate operations found: 7
Operation n°1:
EPSG:15921, Beijing 1954 to WGS 84 (4), 1.0 m, China - Tarim - 77.5°E to 88°E
and 37°N to 42°N
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert
+xy_in=deg +xy_out=rad +step +proj=push +v_3 +step +proj=cart +ellps=krass
+step +proj=helmert +x=15.8 +y=-154.4 +z=-82.3 +step +inv +proj=cart
+ellps=WGS84 +step +proj=pop +v_3 +step +proj=unitconvert +xy_in=rad
+xy_out=deg +step +proj=axisswap +order=2,1
WKT2_2018 string:
COORDINATEOPERATION["Beijing 1954 to WGS 84 (4)",
SOURCECRS[
GEOGCRS["Beijing 1954",
DATUM["Beijing 1954",
ELLIPSOID["Krassowsky 1940",6378245,298.3,
LENGTHUNIT["metre",1]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
CS[ellipsoidal,2],
AXIS["geodetic latitude (Lat)",north,
ORDER[1],
AXIS["geodetic longitude (Lon)",east,
ORDER[2],
ANGLEUNIT["degree",0.0174532925199433]]]],
TARGETCRS[
GEOGCRS["WGS 84",
DATUM["World Geodetic System 1984",
ELLIPSOID["WGS 84",6378137,298.257223563,
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
METHOD["Geocentric translations (geog2D domain)",
ID["EPSG",9603]],
PARAMETER["X-axis translation",15.8,
LENGTHUNIT["metre",1],
ID["EPSG",8605]],
PARAMETER["Y-axis translation",-154.4,
ID["EPSG",8606]],
PARAMETER["Z-axis translation",-82.3,
ID["EPSG",8607]],
OPERATIONACCURACY[1.0],
USAGE[
SCOPE["unknown"],
AREA["China - Tarim - 77.5°E to 88°E and 37°N to 42°N"],
BBOX[37,77.45,41.99,88]],
ID["EPSG",15921]]
Even
http://www.spatialys.com
More information about the PROJ
