[PROJ] PROJ 6.1.0RC1
Bas Couwenberg
sebastic at xs4all.nl
Mon May 6 03:29:26 PDT 2019
On 2019-05-06 11:29, Even Rouault wrote:
>> IIRC epsg:4258 is interpreted as a Geographic 2D CRS which likely
>> causes
>> the 3D component to be ignored.
> Yes, you should use EPSG:4937 (ETRS89 Geographic 3D CRS), but that will
> not
> solve the issue with the Z value. The issue here is that in the
> rdnap:rdnap
> string, the +geoidgrids=naptrans2008.gtx implies a transformation
> between
> WGS84 3D and the vertical CRS implied by naptrans2008.gtx. But you want
> to
> transform between ETRS89 3D and that vertical CRS. As there is no
> transformation registered in the EPSG dataset between WGS84 3D and
> ETRS89 3D
> (there is one only on the 2D part), PROJ cannot use the vertical grid
> What works however is completely dropping the use of rdnap:rdnap and
> using
> EPSG:28992+5709 instead, that is "Amersfoort / RD New + NAP height", as
> there
> is a transformation registered between ETRS89 and NAP height, which
> uses the
> naptrans2008.gtx grid
> $ echo "53.160753042 4.824761912 42.8614" | \
> PROJ_LIB=$PWD:data src/cs2cs -f "%.4f" EPSG:4937 EPSG:28992+5709
> 117380.1203 575040.3399 0.9985
> Which is close to what you get with PROJ 5.2.0 with
> cs2cs -r -f %.4f +init=epsg:4258 +to +init=rdnap:rdnap:
> 117380.1203 575040.3398 1.0000
Using epsg:4937 & epsg:28992+5709 doesn't fix the test failures, while
the debug output is more extensive, I don't see naptrans2008.gtx being
used, only rdtrans2008.gsb.
See the attachment.
>> The projinfo output is not something I can make sense of, it is as
>> follows:
>> $ PROJ_LIB=.:/usr/share/proj projinfo -s EPSG:4258 -t rdnap:rdnap
>> target CRS: parsing of user string failed: crs not found
> Note: you can use +init=rdnap:rdnap to resolved in the rdnap file.
Thanks for the tip. The syntax needs to be changed to include +type=crs
I guess, because it still fails:
$ PROJ_LIB=.:/usr/share/proj projinfo -s EPSG:4258 -t +init=rdnap:rdnap
target CRS string is not a CRS
With the updated rdnap init file:
cat rdnap
# RDNAP with NTv2 and VDatum
<rdnap> +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
+nadgrids=rdtrans2008.gsb +geoidgrids=naptrans2008.gtx +units=m +no_defs
+type=crs <>
# RD with NTv2 only
<rd> +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+nadgrids=rdtrans2008.gsb +units=m +no_defs +type=crs <>
We indeed do get results:
| head -8
Candidate operations found: 1
Operation n°1:
unknown id, unknown + unknown to WGS84 + Inverse of ETRS89 to WGS 84 (1)
+ Transformation from unknown to ETRS89 (ballpark vertical
transformation, without ellipsoid height to vertical height correction),
unknown accuracy, Europe - ETRS89, has ballpark transformation
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert
+xy_in=deg +xy_out=rad +step +inv +proj=hgridshift
+grids=rdtrans2008.gsb +step +proj=sterea +lat_0=52.1561605555556
+lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000
+ellps=bessel
That leads to the question: How backwards compatible is +type=crs?
Kind Regards,
Bas
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190506/09370c8c/attachment-0001.bin>
More information about the PROJ
