[PROJ] PROJ 6.1.0RC1
Bas Couwenberg
sebastic at xs4all.nl
Mon May 6 06:22:44 PDT 2019
On 2019-05-06 15:05, Even Rouault wrote:
>> Removing the cs2cs args and +init= prefix result in the gtx being
>> used,
>> but the magin is still too large.
>> See the attachment.
> ok, so this is on
> Test: 10 edge_rd
> Exec: cs2cs EPSG:28992+5709 +to EPSG:4937 -f %.9f
> Input: 50000.4500 335999.6700
> Output: 51.003976841 3.891248343 44.739810857
> Expect: 51.003976532 3.891247830
> Latitude exceeds 1e-08 degrees: 3.08999993592352e-07
> Longitude exceeds 1e-08 degrees: 5.12999999813246e-07
> With proj 5.2.0:
> $ echo "50000.4500 335999.6700" | ~/proj/install-proj-5.2.0/bin/cs2cs
> +init=rdnap:rdnap +to +init=epsg:4258 -f %.9f
> 3.891248343 51.003976842 44.740002097
> And with proj master/6.1
> $ echo "50000.4500 335999.6700" | PROJ_LIB=$PWD:data src/cs2cs
> EPSG:28992+5709
> So for lat,long I get almost the same values with both PROJ versions
> (1e-9 deg
> difference on latitude). Perhaps the test expected result should be
> updated ?
Tests 07 - 10 are already handled differently, the "Use of RDTRANS2008
and NAPTRANS2008.pdf" [0] documents the following:
Points 07 - 10 are outside the region where interpolation between
either the NLGEO2004 geoid or the RD correction grid points is
possible. RD is defined only within the region enclosed by the
following points (in RD), outside this region RD coordinates can
be computed, but the output should be handled with care.
Corners of the validity region for RD:
│ x (m) │ y (m) │
│ 140000 │ 630000 │
│ 100000 │ 600000 │
│ 80000 │ 500000 │
│ -8000 │ 390000 │
│ -8000 │ 335000 │
│ 100000 │ 335000 │
│ 160000 │ 288000 │
│ 220000 │ 288000 │
│ 301000 │ 450000 │
│ 301000 │ 615000 │
│ 260000 │ 630000 │
The other tests (01 - 06) should all pass with values within the allowed
margin of those expected.
Appendix 2 of the PDF documents the following:
The transformation between ETRS89 and RD/NAP procedure should be tested
in both directions. The
rdtrans2008.gsb consists of one parent grid and one child grid, the
naptrans2008.gtx consists of one
grid, the bounding boxes of the grids, in Bessel-1841 geographic
coordinates, are given by:
NTv2-parent grid NTv2-child grid VDatum-grid
Latitude Minimum 50° 30’ 00.000” 50° 30’ 00.000” 50° 30’ 00.000”
Latitude Maximum 55° 50’ 00.000” 54° 00’ 00.000” 55° 50’ 00.000”
Latitude Interval 00° 05’ 00.000” 00° 00’ 30.000” 00° 00’ 30.000”
Longitude Minimum 02° 30’ 00.000” 03° 00’ 00.000” 02° 30’ 00.000”
Longitude Maximum 07° 40’ 00.000” 07° 40’ 00.000” 07° 40’ 00.000”
Longitude Interval 00° 05’ 00.000” 00° 00’ 30.000” 00° 01’ 00.000”
The coordinates below are computed with the RDNAPTRANSTM2008. the
differences when using the
rdtrans2008.gsb and naptrans2008.gtx grids should not exceed, except
for point 10 (see limitation 2)
of the rdtrans2008 NTv2-grid):
RD x and y coordinates: 0.001 meters
NAP heights and ETRS89 ellipsoidal heights: 0.001 meters
ETRS89 latitude and longitude: 0.00000001 degrees
This margin was not exceeded with PROJ 5.2.0 (for tests 01 - 06).
[0]
https://salsa.debian.org/debian-gis-team/proj-rdnap/blob/debian/2008-8/Use%20of%20RDTRANS2008%20and%20NAPTRANS2008.pdf
Kind Regards,
Bas
More information about the PROJ
