[PROJ] [PROJ 6.1.0] Tests failed on vertical grid shift for France mainland onshore
Didier Richard Didier.Richard at ign.fr
Sat May 18 03:00:20 PDT 2019
Hi all,
While running make check after a fresh install, the following error appeared :
Running ../../test/cli/testprojinfo using ../../src/projinfo:
diff testprojinfo_out with testprojinfo_out.dist
--- testprojinfo_out    2019-05-18 10:52:56.203561622 +0200
+++ ../../test/cli/testprojinfo_out.dist        2019-05-06 07:12:09.000000000 +0200
@@ -762,18 +762,18 @@
 Operation n°1:
-INVERSE(DERIVED_FROM(EPSG)):8371, Inverse of RGF93 to NGF IGN69 height (2), 0.02 m, France - mainland onshore
+INVERSE(DERIVED_FROM(EPSG)):8885, Inverse of RGF93 to NGF IGN69 height (3), 0.01 m, France - mainland onshore
 PROJ string:
-+proj=vgridshift +grids=RAF09.gtx +multiplier=1
++proj=vgridshift +grids=RAF18.gtx +multiplier=1
 Operation n°2:
-INVERSE(DERIVED_FROM(EPSG)):8885, Inverse of RGF93 to NGF IGN69 height (3), 0.01 m, France - mainland onshore
+INVERSE(DERIVED_FROM(EPSG)):8371, Inverse of RGF93 to NGF IGN69 height (2), 0.02 m, France - mainland onshore
 PROJ string:
-+proj=vgridshift +grids=RAF18.gtx +multiplier=1
++proj=vgridshift +grids=RAF09.gtx +multiplier=1
 Operation n°3:
PROBLEMS HAVE OCCURRED
test file testprojinfo_out saved
RAF18.gtx is related to France mainland onshore while RAF09.gtx is related to French Antilla.
Looking at sql files :
sql/grid_transformation.sql:INSERT INTO "grid_transformation" VALUES('EPSG','8371','RGF93 to NGF IGN69 height (2)',NULL,NULL,'EPSG','1073','Geographic3D to GravityRelatedHeight (IGN2009)','EPSG','4965','EPSG','5720','EPSG','1326',0.02,'EPSG','8666','Geoid (height correction) model file','RAF09.mnt',NULL,NULL,NULL,NULL,NULL,NULL,'IGN Fra 09',0);
sql/grid_transformation.sql:INSERT INTO "grid_transformation" VALUES('EPSG','8885','RGF93 to NGF IGN69 height (3)',NULL,NULL,'EPSG','1073','Geographic3D to GravityRelatedHeight (IGN2009)','EPSG','4965','EPSG','5720','EPSG','1326',0.01,'EPSG','8666','Geoid (height correction) model file','RAF18.tac',NULL,NULL,NULL,NULL,NULL,NULL,'IGN Fra 18',0);
sql/supersession.sql:INSERT INTO "supersession" VALUES('grid_transformation','EPSG','8371','grid_transformation','EPSG','8885','EPSG');
-- Remove supression entry of EPSG:8371 ("RGF93 to NGF IGN69 height (2)", using RAF09.mnt) by
-- EPSG:8885 ("RGF93 to NGF IGN69 height (3)", using RAF18.tac), since
-- we have only RAF09.mnt in proj-datumgrid-europe
-- Our code to remove superseded operations should probably take into account grid availability
DELETE FROM "supersession" WHERE superseded_table_name = 'grid_transformation' AND
                                 superseded_auth_name = 'EPSG' AND
                                 superseded_code = '8371' AND
                                 replacement_table_name = 'grid_transformation' AND
                                 replacement_auth_name = 'EPSG' AND
                                 replacement_code = '8885' AND
                                 source = 'EPSG';
There seams to have no difference between these lines in 6.0.0 and 6.10 sql files.
Any idea ?
Best regards,
RICHARD Didier - Chef du Centre de Compétences Technologies des Systèmes d'Information
http://fr.linkedin.com/pub/didier-richard/98/2a3/a8/ - https://www.osgeo.org/member/didier/
IGN/Direction des Sciences et Technologies de l'Information/ENSG Géomatique
6/8 avenue Blaise Pascal - BP Champs-sur-Marne - 77455 MARNE-LA-VALLÉE CEDEX 2
Tél : +33 (0) 1 43 98 83 23
More information about the PROJ mailing list
