[PROJ] Obtaining possible transformation pipelines
Even Rouault
even.rouault at spatialys.com
Mon May 27 10:23:27 PDT 2019
> If I have a proj string representing a coordinate operation, is there
> any way to determine what grids are required for using it when those
> grids are NOT available for use on the system?
I don't think so. As you find out, PROJ will refuse to instanciate a
coordinate operation from a PROJ string that has a grids not present on the
system.
Asthere are not so many ways of expressing grids in PROJ grids, basically you
could look for +grids=xxxxx
Even
http://www.spatialys.com
More information about the PROJ
