[PROJ] PSC Motion: require SQLite 3.11 as minimum version
Paul Ramsey
pramsey at cleverelephant.ca
Thu Nov 7 07:46:32 PST 2019
Some packagers may now feel punished for getting on the Proj6 train. They’d have been better off just continuing with Proj4 and waiting out the transition for a couple more years.
This isn’t an optional requirement for Proj6, basically it’s an unusably bad performance regression, so using Proj6 requires a newer SQLite given current state. The Motion is sort of beside the point, it’s just a technical fact.
P.
> On Nov 7, 2019, at 6:52 AM, Howard Butler <howard at hobu.co> wrote:
> +0. I'd like to hear from the packagers on this. We're already making life complicated for them, and SQLite is a frequently referenced dependency. Does 3.11 pick up common RHEL/Centos installations? Android/iOS?
> Howard
>> On Nov 7, 2019, at 8:50 AM, Howard Butler <howard at hobu.co> wrote:
>>> On Nov 7, 2019, at 8:15 AM, Even Rouault <even.rouault at spatialys.com> wrote:
>>> Hi,
>>> It has been reported that PROJ 6.2.1 (also applies to master) runs super slow
>>> if used with a too old SQLite version (https://github.com/OSGeo/PROJ/issues/
>>> 1718). It works fine with SQLite 3.11 (as found on Ubuntu 16.04 for example).
>>> SQLite 3.11 was released on 2016-02-15, so meets our "older than 2 years"
>>> rule.
>>> Hence the following motion
>>> Require SQLite 3.11 for PROJ master
>>> +1 Even
>>> PR implementing this ready in https://github.com/OSGeo/PROJ/pull/1721
>>> Will apply for PROJ 6.3
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
>>> PROJ mailing list
>>> PROJ at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
More information about the PROJ
