[PROJ] PSC Motion: require SQLite 3.11 as minimum version
Even Rouault
even.rouault at spatialys.com
Thu Nov 7 07:57:10 PST 2019
> This isn’t an optional requirement for
> Proj6, basically it’s an unusably bad performance regression, so using
> Proj6 requires a newer SQLite given current state.
Agreed. This probably mostly affects RHEL 7 which, while not being antiquated
from the point of view of RedHat's release policies, still ships with outdated
components by todays' standards. So RHEL 7 users have two options: use PROJ
5.x or PROJ 6 + backported SQLite.
> The Motion is sort of
> beside the point, it’s just a technical fact.
This motion is mostly purely procedural to be in compliance with
"Changing the version requirements for a dependency needs to be approved by
the PSC."
of https://proj.org/community/rfc/rfc-3.html as Kristian reminded me.
Even
http://www.spatialys.com
More information about the PROJ
