[PROJ] "Trustworthiness" of vertical transformations
    Even Rouault
    even.rouault at spatialys.com
    Thu Nov 28 03:25:55 PST 2019
On jeudi 28 novembre 2019 01:49:35 CET Chris Crook wrote:
> Am I right in understanding that where proj (6) determines two or more
> possible transformation paths between CRSs it uses the accuracy to decide
> which is preferable?
The long answer would be long :-) Trying to do a medium one. There are several
levels of API. In the low level of API, PROJ enumerates the possible
transformation paths from its database and a set of heuristics, and then
return them in a sorted way, trying to put the most relevant at top. The
criterion include area of use, accuracy, availability of grids. The user can
then decide which one is appropriate for its use case
The higher level of API ("black box") will use those results to automatically
select the one that is "best" for the coordinate to transform.
So yes, given 2 transformation paths that have the same are of use and where
the needed grid(s) are available, advertized accuracy will decide which one is
to be used.
I didn't mention deprecation and supersession information coming from EPSG
which are also taken into account.
> Also geodetic agencies defining parameters will need to be careful that
> accuracies are configured to ensure the desired preference is achieved.  In
> the past it is likely that not much attention would have been given to this
> as it isn't necessarily very meaningful (certainly not as a single value)
> and until now possibly didn't make much difference to anything...
Yes, an example of the consequence of this in:
https://github.com/OSGeo/PROJ/issues/1580#issuecomment-528042944
Even
http://www.spatialys.com
More information about the PROJ
