[PROJ] Code of conduct
Even Rouault even.rouault at spatialys.com
Thu Oct 17 12:36:52 PDT 2019
On jeudi 17 octobre 2019 21:24:02 CEST Kristian Evers wrote:
> PROJ is very close to graduating as an OSGeo project. On the Incubation
> mailing list [0] Jody has asked that the project adopt a code of conduct.
> This is a new requirement for OSGeo projects that has not yet been added
> to the incubation checklist. OSGeo more or less enforces the use of the
> Contributor Covenant code of conduct[1][2].
> The wording in the Contributor Covenant has been carefully chosen and
> reviewed by a large audience. Personally I think it contains solid
> principles for a community like ours to follow.
> I have prepared a pull request [3] with the necessary changes to adopt the
> code of conduct. I will not merge it before we’ve had a discussion about the
> code of conduct and it’s use in the PROJ community. I believe adopting a
> CoC is substantial enough decision for the project that it warrants a PSC
> vote.
> Please share your thoughts on adopting a code of conduct.
+1 for Contributor Covenant
http://www.spatialys.com
More information about the PROJ mailing list
