[PROJ] Code of conduct
Kristian Evers
kristianevers at gmail.com
Thu Oct 17 12:24:02 PDT 2019
PROJ is very close to graduating as an OSGeo project. On the Incubation
mailing list [0] Jody has asked that the project adopt a code of conduct.
This is a new requirement for OSGeo projects that has not yet been added
to the incubation checklist. OSGeo more or less enforces the use of the
Contributor Covenant code of conduct[1][2].
The wording in the Contributor Covenant has been carefully chosen and
reviewed by a large audience. Personally I think it contains solid principles
for a community like ours to follow.
I have prepared a pull request [3] with the necessary changes to adopt the
code of conduct. I will not merge it before we’ve had a discussion about the
code of conduct and it’s use in the PROJ community. I believe adopting a
CoC is substantial enough decision for the project that it warrants a PSC vote.
Please share your thoughts on adopting a code of conduct.
/Kristian
[0] https://lists.osgeo.org/pipermail/incubator/2019-October/004006.html <https://lists.osgeo.org/pipermail/incubator/2019-October/004006.html>
[1] https://www.osgeo.org/code_of_conduct/ <https://www.osgeo.org/code_of_conduct/>
[2] https://www.contributor-covenant.org/ <https://www.contributor-covenant.org/>
[3] https://github.com/OSGeo/PROJ/pull/1681 <https://github.com/OSGeo/PROJ/pull/1681>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20191017/98431c52/attachment.html>
More information about the PROJ
