[PROJ] Code of conduct
Kurt Schwehr
schwehr at gmail.com
Thu Oct 17 13:10:18 PDT 2019
+1 Kurt
Maybe hold off on submitting the pull request until it's had some time
(maybe a week?) for people to speak up?
On Thu, Oct 17, 2019 at 12:24 PM Kristian Evers <kristianevers at gmail.com>
wrote:
> PROJ is very close to graduating as an OSGeo project. On the Incubation
> mailing list [0] Jody has asked that the project adopt a code of conduct.
> This is a new requirement for OSGeo projects that has not yet been added
> to the incubation checklist. OSGeo more or less enforces the use of the
> Contributor Covenant code of conduct[1][2].
> The wording in the Contributor Covenant has been carefully chosen and
> reviewed by a large audience. Personally I think it contains solid
> principles
> for a community like ours to follow.
> I have prepared a pull request [3] with the necessary changes to adopt the
> code of conduct. I will not merge it before we’ve had a discussion about
> the
> code of conduct and it’s use in the PROJ community. I believe adopting a
> CoC is substantial enough decision for the project that it warrants a PSC
> vote.
> Please share your thoughts on adopting a code of conduct.
> /Kristian
> [0] https://lists.osgeo.org/pipermail/incubator/2019-October/004006.html
> [1] https://www.osgeo.org/code_of_conduct/
> [2] https://www.contributor-covenant.org/
> [3] https://github.com/OSGeo/PROJ/pull/1681
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20191017/db30a2e0/attachment.html>
More information about the PROJ
