[PROJ] Future maintainance releases
Even Rouault even.rouault at spatialys.com
Tue Oct 29 14:57:31 PDT 2019
I'm doing currently fixes/enhancements in the vertical transformation sector.
Backporting them to 6.2 branch would mostly mean just merging master into
it..., so I think that for future maintainance releases post 6.2.1 we should
probably abandon any further activity in 6.2 (apart from website/doc related
fixes since we generate it from them, or a urgent hotfix if some horrible
regression was identified), and create a branch from master when we're about
to release, and call it 6.3. API & behaviour wise, master is currently
compatible with 6.2. There are a few database structure changes, but I'm not
aware of users who are dependent on it.
But if any of the 2 following pieces of work happens before, then we'll have
to consider if we want to create this 6.3 branch before they are merged,
depending on how close they happen from the next planned release:
- EPSG v10 related work (no funding source identified for now): anticipated
non trivial implications on the database structure and code
- Ondemand network loading of grids (aka "PROJ grid files CDN" topic [1], 50%
of funding target reached)
The question PROJ 7 or not (if by PROJ 7 we mean removing proj_api.h) will
also need to be considered. There are still important dependencies like
Spatialite who haven't yet released a version without proj_api.h dependency
(as far as I can see from [2], the 'master' contains the changes to use proj.h
though)
Even
[1] https://lists.osgeo.org/pipermail/proj/2019-September/008858.html
[2] https://www.gaia-gis.it/fossil/libspatialite/info/b72ce4b2a5c7eb77
http://www.spatialys.com
More information about the PROJ mailing list
