[PROJ] Future maintainance releases
Sebastiaan Couwenberg
sebastic at xs4all.nl
Tue Oct 29 21:00:57 PDT 2019
On 10/29/19 10:57 PM, Even Rouault wrote:
> The question PROJ 7 or not (if by PROJ 7 we mean removing proj_api.h) will
> also need to be considered. There are still important dependencies like
> Spatialite who haven't yet released a version without proj_api.h dependency
> (as far as I can see from [2], the 'master' contains the changes to use proj.h
> though)
If you don't remove proj_api.h, downstream projects are not motivated
enough to switch to proj.h. Many project have just defined
ACCEPT_USE_OF_DEPRECATED_PROJ_API_H to fix their builds with PROJ 6.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
More information about the PROJ
