[PROJ] OSGeo incubation status
Kurt Schwehr
schwehr at gmail.com
Mon Sep 9 20:58:58 PDT 2019
Thank you all for the work on the incubation!
Yet another vote for avoiding a CLA.
On Mon, Sep 9, 2019 at 2:26 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 9 septembre 2019 21:20:36 CEST Even Rouault wrote:
> > > For other files, "git log" on them and finding the original committer
> > > should be good enough.
> > "git log --follow" to be more exact due to renaming/moving around.
> OK, I did the exercice of completing Kristian's initiated source file
> listing
> https://docs.google.com/spreadsheets/d/1Bdu73lw8I1iFX4cb7CIUF6yqWGDTcZKBfW0cUsEjCXk/edit#gid=0
> Would be worth being double checked of course.
> I've followed an "optimistic" principle, that is to say that we don't have
> issues
> unless strong suspicion of the contrary: PROJ has always been released with
> Copyright (c) 2000, Frank Warmerdam as the general license, so I think it
> is the
> reasonable to consider this as the base to use for contributions
> unless they state explicitly something else.
> The general rules I followed in the case there's no explicit header with
> copyright & license are:
> - files coming from initial commit by Frank in 1999 and present in PROJ
> 4.3 are copyright Frank
> - files without explicit header and coming from SVN or git era are
> copyright their author
> when it can be recovered from the commit message, or otherwise the
> committer (Frank most of the times)
> I've indicated those 2 situations in the remarks column.
> There are a few lines underlined in yellow that might require follow up
> actions.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190909/97093815/attachment-0001.html>
More information about the PROJ
