[PROJ] PROJ logo proposal
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Thu Sep 12 03:13:25 PDT 2019
Hi Nick,
+1 for 1A
I like the idea of a letter P consisting of a ruler and a globe too. So, I am interested in your additional drafts.
Kind regards, Jochem
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Nicolas B.
Sent: dinsdag 10 september 2019 16:09
To: proj at lists.osgeo.org
Subject: [PROJ] PROJ logo proposal
Hi list,
Following a discussion with Kristian in late 2018 , i am glad to finally share a few logotypes for your consideration. I fully agree that PROJ needs a logo and that would be the perfect touch for upcoming incubation :)
https://nbozon.github.io/OSGeo/proj/PROJ_logo_proposal.pdf
This is a draft proposal at this stage, and i would be glad to work further on one particular logo that you may like, using the community feedbacks.
Please note:
- These are only logotypes. Logotexts can also be created, or the 'PROJ' word may be added to any of these (this involves we may select a particular open font).
- These are simple SVG shapes provided in black color for now
(Colors can of course be proposed later on, if you like one of these)
- This work is licensed under CC BY-NC 4.0 at this stage, but i am happy to create new version using a more permissive license if needed.
- I have more SVG drafts based on the 'P' letter, as well as additional ideas using axis and coords elements, but i unfortunately can't shared them for now.
- I am sharing this document as PDF for the sake of simplicity, but i am happy to provide the source SVG at a later stage, along different formats so we could easily reuse it on website and OSGeo marketing material.
This is only a simple proposal and i hope you will like it.
I am looking for your feedbacks, and will be glad to use one of these in order to create the perfect logo, with colors and text.
Best regards,
Nick
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190912/36d4a3b0/attachment.html>
More information about the PROJ
