[PROJ] Vertical CRS transformations and vertical grid shift
Even Rouault
even.rouault at spatialys.com
Fri Apr 17 03:27:26 PDT 2020
> I'm not sure to have fully understood how the bilinear interpolation is
> being used in this process.
Hopefully as (loosely) described in http://www.epsg.org/Portals/0/373-07-2.pdf , "4.10.2
Vertical Offset by Interpolation of Gridded Data"
Implementation starting at:
https://github.com/OSGeo/PROJ/blob/master/src/grids.cpp#L3178
> Could you please do an example?
Left as an exercice to the reader: peek a point on a grid intersection, look at the value in the
grid file and verify that PROJ exactly offsets elevation by this value. Now takes a point at the
middle of 4 grid nodes, compute the mean, and check that PROJ applies this interpolated
value.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200417/bbee327b/attachment.html>
More information about the PROJ
