[PROJ] Vertical CRS transformations and vertical grid shift
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Fri Apr 17 03:51:45 PDT 2020
Thanks! I'll check that doc.
Regards,
Daniele
On Fri, Apr 17, 2020 at 12:27 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> > I'm not sure to have fully understood how the bilinear interpolation is
> > being used in this process.
> Hopefully as (loosely) described in
> http://www.epsg.org/Portals/0/373-07-2.pdf , "4.10.2 Vertical Offset by
> Interpolation of Gridded Data"
> Implementation starting at:
> https://github.com/OSGeo/PROJ/blob/master/src/grids.cpp#L3178
> > Could you please do an example?
> Left as an exercice to the reader: peek a point on a grid intersection,
> look at the value in the grid file and verify that PROJ exactly offsets
> elevation by this value. Now takes a point at the middle of 4 grid nodes,
> compute the mean, and check that PROJ applies this interpolated value.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200417/b6625f16/attachment-0001.html>
More information about the PROJ
