[PROJ] PROJ 7.0.1RC1 & 6.3.2RC1
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Apr 29 10:55:11 PDT 2020
Hi Kristian,
7.0.1RC1 builds fine on Windows.
Environment:
   - VC2017
   - curl 7.70.0
   - libtiff 4.1.0
   - sqlite 3.31.1
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeo.com/
On 2020-04-27 6:22 a.m., Kristian Evers wrote:
> All,
> With scheduled releases of PROJ 7.0.1 and 6.3.2. on May 1st it is time
> to put out release candidates. Both candidates includes a number of bug
> fixes since the previous release. 7.0.1 includes 39 bug fixes and 16 bugs
> has been fixed in 6.3.2. See the release notes below.
> Archives are available here:
> http://download.osgeo.org/proj/proj-7.0.1RC1.tar.gz
> http://download.osgeo.org/proj/proj-7.0.1RC1.zip
> http://download.osgeo.org/proj/proj-6.3.2RC1.tar.gz
> http://download.osgeo.org/proj/proj-6.3.2RC1.zip
> Please test the release candidates and report back any problems you
> may encounter.
> If no issues are found with the two release candidates the final releases
> will be announced on Friday May 1st.
> /Kristian
> 7.0.1 Release Notes
>   Updates
>   o Database: update to EPSG v9.8.9 #2141
>   Bug fixes
>   o Make tests independent of proj-datumgrid (#1995)
>   o Add missing projection property tables (#1996)
>   o Avoid crash when running against SQLite3 binary built with
>     -DSQLITE_OMIT_AUTOINIT (#1999)
>   o createOperations(): fix wrong pipeline generation with CRS that has +nadgrids=
>     and +pm= (#2002)
>   o Fix bad copy&replace pattern on HEALPix and rHEALPix projection names (#2007)
>   o createUnitOfMeasure(): use full double resolution for the conversion
>     factor (#2014)
>   o Update README with info on PROJ-data (#2015)
>   o utm/ups: make sure to set errno to PJD_ERR_ELLIPSOID_USE_REQUIRED if
>     es==0 (#2045)
>   o data/Makefile.am: remove bashism (#2048)
>   o ProjectedCRS::identify(): tune it to better work with ESRI WKT
>     representation of EPSG:2193 (#2059)
>   o Fix build with gcc 4.8.5 (#2066)
>   o Autotools/pkg-conf: Define datarootdir (#2069)
>   o cs2cs: don't require +to for '{source_crs} {target_crs} filename...'
>     syntax (#2081)
>   o CMake: fix bug with find_package(PROJ) with macOS (#2082)
>   o ESRI WKT import / identification: special case for
>     NAD_1983_HARN_StatePlane_Colorado_North_FIPS_0501 with Foot_US unit (#2088)
>     NAD_1983_HARN_StatePlane_Colorado_North_FIPS_0501 with Foot_US unit (#2089)
>   o EngineeringCRS: when exporting to WKT1_GDAL, output unit and axis (#2092)
>   o Use jtsk03-jtsk horizontal grid from CDN (#2098)
>   o CMake: prefer to use use PROJ_SOURCE_DIR and PROJ_BINARY_DIR (#2100)
>   o Fix wrong grids file name in esri.sql (#2104)
>   o Fix identification of projected CRS whose name is close but not strictly
>     equal to a ESRI alias (#2106)
>   o Fix working of Helmert transform between the horizontal part of
>     2 compoundCRS (#2111)
>   o Database: fix registration of custom entries of grid_transformation_custom.sql
>     for geoid grids (#2114)
>   o ESRI_WKT ingestion: make sure to identify to non-deprecated EPSG entry when
>     possible (#2119)
>   o Make sure that importing a Projected 3D CRS from WKT:2019 keeps the base
>     geographic CRS as 3D (#2125)
>   o createOperations(): improve results of compoundCRS to compoundCRS case (#2131)
>   o hgridshift/vgridshift: defer grid opening when grid has already
>     been opened (#2132)
>   o Resolve a few shadowed declaration warnings (#2142)
>   o ProjectedCRS identification: deal with switched 1st/2nd std parallels for
>     LCC_2SP(#2153)
>   o Fix Robinson inverse projection (#2154)
>   o createOperations(): do not remove ballpark transformation if there are only
>     grid based operations, even if they cover the whole area of use (#2156)
>   o createFromCoordinateReferenceSystemCodes(): 'optimization' to avoid using
>     C++ exceptions (#2161)
>   o Ingestion of WKT1_GDAL: correctly map 'Cylindrical_Equal_Area' (#2167)
>   o Add limited support for non-conformant WKT1 LAS COMPD_CS[] (#2172)
>   o PROJ4 string import: take into correctly non-metre unit when the string
>     looks like the one for WGS 84 / Pseudo Mercator (#2177)
>   o io.hpp: avoid dependency to proj_json_streaming_writer.hpp (#2184)
>   o Fix support of WKT1_GDAL with netCDF rotated pole formulation (#2186)
> 6.3.2 Release Notes
>   Bug fixes
>   o validateParameters(): fix false-positive warning on
>     Equidistant Cylindrical (#1947)
>   o proj_create_crs_to_crs(): avoid potential reprojection failures when
>     reprojecting area of use to source and target CRS (#1993)
>     and +pm= (#2003)
>   o Fix bad copy&replace pattern on HEALPix and rHEALPix projection names (#2006)
>     factor (#2013)
>   o data/Makefile.am: remove bashism (#2047)
>   o ProjectedCRS::identify(): tune it to better work with ESRI WKT representation
>     of EPSG:2193 (#2058)
>   o EngineeringCRS: when exporting to WKT1_GDAL, output unit and axis (#2091)
>   o Add missing entries in grid_alternatives for Portugal grids coming from
>     ESRI entries (#2103)
>   o Fix working of Helmert transform between the horizontal part of 2
>     compoundCRS (#2110)
>     possible (#2118)
>     geographic CRS as 3D (#2124)
>   o createOperations(): improve results of compoundCRS to compoundCRS case (#2130)
>   o PROJ4 string import: take into correctly non-metre unit when the string looks
>     like the one for WGS 84 / Pseudo Mercator (#2178)
>   o Fix support of WKT1_GDAL with netCDF rotated pole formulation (#2187)
>   o io.hpp: avoid dependency to proj_json_streaming_writer.hpp (#2188)
More information about the PROJ mailing list
