[PROJ] 7.2.1 RC1 ob_tran changes break existing logic
Even Rouault even.rouault at spatialys.com
Mon Dec 28 08:11:16 PST 2020
On lundi 28 décembre 2020 16:41:09 CET Kristian Evers wrote:
> Thanks for clearing this up, Even. The workflow is a bit cumbersome but with
> the knowledge you’ve provided here it should be possible for Roger to adapt
> the code to work around this.
> I agree that a function to determine if a CRS is derived would be a nice
> addition.
Queued in https://github.com/OSGeo/PROJ/pull/2496 . I've targetted it for 8.0
. Could be easily backported if deemed necessary.
> I guess this problem mostly shows up because ob_tran is a bit of a weird
> projection. It is often the cause of problems. I wonder if it is time to
> get rid of it
Although I concur it is an annoyance, I can't see how we could get rid of it.
There are definitely use cases where people want a CRS object expressing such
rotation.
http://www.spatialys.com
More information about the PROJ mailing list
