[PROJ] 7.2.1 RC1 ob_tran changes break existing logic
Roger Bivand Roger.Bivand at nhh.no
Tue Dec 29 07:35:20 PST 2020
On Mon, 28 Dec 2020, Even Rouault wrote:
> On lundi 28 décembre 2020 16:41:09 CET Kristian Evers wrote:
>> Thanks for clearing this up, Even. The workflow is a bit cumbersome but
>> with the knowledge you’ve provided here it should be possible for Roger
>> to adapt the code to work around this.
>> I agree that a function to determine if a CRS is derived would be a nice
>> addition.
> Queued in https://github.com/OSGeo/PROJ/pull/2496 . I've targetted it for 8.0
> . Could be easily backported if deemed necessary.
Thanks! Handled with
if (proj_get_type(target_crs) == PJ_TYPE_GEOGRAPHIC_2D_CRS && use_ob_tran)
         if ((source_crs = proj_get_source_crs(PJ_DEFAULT_CTX, target_crs))
== 0)
where use_ob_tran is declared by the user as TRUE if the user wishes, and
the involved CRS include the proj=ob_tran string.
Tested OK with 7.2.1 RC1 and 7.2.0; now need to check for earlier
releases. Current code on R-Forge SVN, revisions 1086-1088.
Roger
>> I guess this problem mostly shows up because ob_tran is a bit of a
>> weird projection. It is often the cause of problems. I wonder if it is
>> time to get rid of it
> Although I concur it is an annoyance, I can't see how we could get rid
> of it. There are definitely use cases where people want a CRS object
> expressing such rotation.
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the PROJ mailing list
